Date/Time: Tue, 17 Nov 2026 16:32:21 +0000
trade sound alerts
View Count: 2859
| [2019-09-03 17:55:06] |
| User972583 - Posts: 3 |
HI i have set some sound alerts for trading. fills, stops, etc. None of the set sounds are working. I cannot figure out why. see settings screen shot. any ideas? |
| Attachment Deleted. |
| [2019-09-03 18:41:06] |
| Ackin - Posts: 1866 |
Hi, Try 1) Menu / General Settings/Alerts/General 3 - "Test Sound" ... check your sound file 2) Menu Global Settings/ Mute all alerts sounds |
| [2019-09-03 19:26:43] |
Follow-through the instructions here: General Settings Window: Troubleshooting for Alert Sounds That Do Not Play Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
