Date/Time: Fri, 03 May 2024 15:02:26 +0000
TPO Profile Chart study and Replay chart
View Count: 1349
[2013-12-10 15:21:25] |
User16114 - Posts: 153 |
Can anyone tell me if "Replay Chart" works with an Intraday chart (.scid) with "TPO Profile Chart" study?
[2013-12-10 15:44:32] |
Sierra Chart - Max - Posts: 5599 |
Yes, TPO Profile Charts do work with replays.
Sierra Chart Support |
[2013-12-10 20:01:11] |
I have read the documentation and I am still having difficulty getting replay to work. I am using AMP/TTNet and IQFeed in two instances of SC. Do I need to do anything special to get replay to work? Can you list common things to look out for to get it working. Thanks.
[2013-12-10 23:48:01] |
Nothing special to do. You simply need to scroll the chart back and start the replay. Here are the instructions: http://www.sierrachart.com/index.php?l=doc/doc_ReplayChart.html#BasicInstructions We assume this is an Intraday chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-11 12:57:37] |
thnx SC got it working - for anyone who is interested - I think my issue was not scrolling back the chart properly SC (or anyone) how do I get rid of the "Replay/BkTest Fills" message that is still on the chart (top left) after closing the Replay Control box? Replay Chart is an awesome feature BTW... |
[2013-12-11 18:30:41] |
SC (or anyone) how do I get rid of the "Replay/BkTest Fills" message that is still on the chart (top left) after closing the Replay Control box? It is possible to customize the other items on the chart header through Global Settings >> Customize Chart Header. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
