Date/Time: Sun, 19 May 2024 02:03:01 +0000
ACSIL Manual for new functions SC1973 sc.StartChartReplay....??
View Count: 1269
[2019-08-29 18:25:56] |
TedMar - Posts: 189 |
any idea when u add Manual for Sc1973 realeased funktions ? New ACSIL functions added: sc.StartChartReplay(), sc.StopChartReplay(), sc.PauseChartReplay(), sc.ResumeChartReplay(), sc.ChangeChartReplaySpeed(), sc.GetStudyProfileInformation(), sc.GetStudySubgraphColors(), sc.SetStudySubgraphColors(), sc.ApplyStudyCollection(), sc.IsChartZoomInStateActive(), sc.GetTradeStatisticsForSymbolV2() |
[2019-09-03 16:25:22] |
Chad - Posts: 231 |
bump - I'm interested as well
[2019-09-03 16:52:37] |
Ackin - Posts: 1865 |
+1 mainly for this sc.ApplyStudyCollection(), sc.IsChartZoomInStateActive(), sc.GetTradeStatisticsForSymbolV2() |
[2019-09-06 04:34:41] |
This will be done as soon as we can.
[2019-09-18 15:58:19] |
Chad - Posts: 231 |
@SCE, could you add just a list of structure members or parameters for the sc.ApplyStudyCollection() & sc.StartChartReplay() to the docs soon? Also, if the user issued a command using the sc.ApplyStudyCollection() to a Chart window with another Study Collection already applied, will it simply remove those existing studies and add the new ones, as part of the collection, without any warnings/errors? |
[2019-09-18 16:13:49] |
We gradually are working on these. This function is now documented: sc.StartChartReplay() Also, if the user issued a command using the sc.ApplyStudyCollection() to a Chart window with another Study Collection already applied, will it simply remove those existing studies and add the new ones, as part of the collection, without any warnings/errors? There is a parameter which controls this. No matter how that parameter is set, there are no prompts.
[2019-09-19 01:39:23] |
Chad - Posts: 231 |
What is/are the primary difference(s) between GetTradeStatisticsForSymbol() and GetTradeStatisticsForSymbolV2()?
