Date/Time: Tue, 07 May 2024 12:43:34 +0000
Alerts sound
View Count: 1093
[2013-12-10 09:38:40] |
User59474 - Posts: 13 |
Hi, Why do the alerts sounds produce the same sound? I guess it's a setting stuff, how can i fix this to have several different sounds? And can i choose my own sounds? Thanks |
[2013-12-10 12:03:22] |
tobi - Posts: 351 |
Yes, it's a setting thing. Please see here: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings |
[2013-12-10 12:52:29] |
Thanks a lot, this was helpful, i fixed the problem. Cheers! |
[2013-12-10 19:26:28] |
The documentation linked to in post #2 is the correct reference for this.
[2013-12-11 03:16:19] |
Follow the documentation here to configure the sounds: http://www.sierrachart.com/index.php?l=doc/doc_GeneralSettings.html#AlertSoundSettings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
