Date/Time: Wed, 08 May 2024 22:55:40 +0000
Arrow Text not Right-Aligning
View Count: 576
[2019-08-29 16:29:52] |
kas64h - Posts: 87 |
Text on Arrow Drawings does not seem to be right-aligning correctly. The text is right-aligned but seems pushed too far to the left and in proportion to it's length. So the text 12345 appears right-aligned as 12345 |Arrow Body here (i.e. 5 spaces between the end of the text and the actual Arrow) Thanks. Date Time Of Last Edit: 2019-08-30 06:56:30
[2019-09-12 14:15:20] |
Hi - I'm not too sure what's happening with this issue? The day I submitted the posting, I received a standard Sierra email reply, starting: 'John - SC Support has posted to the thread: "Arrow Text not Right-Aligning".' I couldn't then, and still can't see any reply on the thread. I've downloaded the latest release and a further pre-release, but the behaviour seems the same. I've included the following image to help illustrate the issue (the text is Right/Bottom aligned): http://www.sierrachart.com/image.php?Image=1568295004142.png There seem to be other issues too (for example, if the arrow head is at the base of the drawing, and the text is Left/Top aligned, it seems to end up right-aligning). I don't want to include lots of examples or images, but unless I'm misinterpreting the intended behaviour, this appears to require further investigation. Please advise (I can submit more images if required). Thanks. |
