Date/Time: Thu, 09 May 2024 06:52:31 +0000
TPO History
View Count: 1120
[2019-08-29 00:00:52] |
User780420 - Posts: 4 |
Is there a way to download a symbol history, say /ES or /CL, of the data from a TPO chart? For example, if I want to capture the tick range of each 30 minute interval historically from a TPO, including the high and low value of each 30 minute interval, and the daily POC, the daily value area high/low, the daily open and close as well as the open and close of each TPO letter, the half back, etc. For a date range... is that possible? I guess i'm looking to transfer the data from a TPO to a spreadsheet. Thanks. Edit: Although I have had no luck extracting the data, most of the data I would like to export is contained in the "Chart Values Window," although in a cumbersome way. TO manually see the data for each 30 minute TPO slice, if I split the TPO and open the Values Window for each time period, those are mainly the statistics I am looking to export. If there was a way to export that Chart Value Window data into a CSV or Excel for each 30 minute time period of the TPO, and then for the entire TPO as a whole for each session (to accurately capture the daily statistics overall without having to parse that from the 30 minute slices). Thanks. Date Time Of Last Edit: 2019-08-29 00:55:39
[2019-10-29 11:32:55] |
This had gotten overlooked. There is a way to do this. Refer to: Time Price Opportunity (TPO) Profile Charts: Programmatically Accessing TPO Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
