Date/Time: Sun, 19 May 2024 07:51:03 +0000
Daily Range Bands not showing
View Count: 587
[2019-08-28 19:16:18] |
arruga - Posts: 249 |
I got the Daily Range Bands study set up as in any other of mycharts. In all my charts, it works fine... except this one: http://www.sierrachart.com/image.php?Image=1567019568473.png Above the chart, the indicator values appear to be zeros. It's as though isn't calculating anything How can I debug this? I'm using the daily ATR to display the daily bands on the hourly chart I've deleted/downloaded recalculated my daily and hourly charts... doesn't solve it It does work fine on any other chart, but this one. What could it be? |
[2019-08-29 04:22:43] |
There is no way we can answer this unless you provide us a Chartbook with the two charts which are used for the Daily Range Bands. Refer to: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
