Date/Time: Sun, 05 May 2024 07:22:43 +0000
Shortcut to swith Chartbooks
View Count: 1790
[2019-08-28 12:34:54] |
User541156 - Posts: 67 |
Couldn't figure it out or find any old post on the forum. Can we somehow set a keyboard shortcut to switch between different chartbooks? |
[2019-08-28 18:02:18] |
There are Control Bar buttons for this: Control Bar: Control Bar Chartbook Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-29 02:17:01] |
Thank you. And is it possible assign keyboard shortcuts to these control bar buttons? |
[2019-08-29 03:17:05] |
Not yet but we are going to add that capability in about two weeks or so.
[2020-07-06 02:11:03] |
User790545 - Posts: 41 |
Has this been implemented yet in release 2130?
[2020-07-07 09:03:12] |
Refer to the documentation here for this: Control Bar: Control Bar Chartbook Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-07 09:03:18
