Date/Time: Sun, 19 May 2024 06:58:29 +0000
3 Contract Order: Stop on All ~ Target on 2 ~ Trailing Stop on One
View Count: 1126
[2019-08-28 02:28:55] |
ondafringe - Posts: 248 |
Can't seem to get this figured out. I want to place a limit order on three contracts. All three need a 4 tick stop One needs a target of 8 ticks One needs a target of 16 ticks One needs to move the stop to break even at 16 ticks... and at 20 ticks, stop needs to change to a 20 tick trailing stop The way I have it (see attachment), I get an error message saying "Qty 3 Target/Stops No Match" Thank you |
SC-TrgTrlStp01.PNG / V - Attached On 2019-08-28 02:13:34 UTC - Size: 15.14 KB - 321 views |
[2019-08-28 05:24:18] |
That does look correct and you can safely ignore that error. You can submit this set of Attached Orders with the main order and it will work properly.
