Date/Time: Sun, 19 May 2024 08:28:21 +0000
File Size
View Count: 965
[2019-08-27 12:12:39] |
User98657 - Posts: 304 |
The SC folder on my C Drive was up to 135GB. I've deleted all the old historical charts, and daily charts. I don't have any unused symbols. This cleanup brought the folder size down to 97GB. Is that what i should be expecting in terms of size, or is there more i can do to reduce the footprint? |
[2019-08-27 17:28:19] |
It is hard for us to say what an appropriate size is, as there are too many factors involved. But refer to the following for information on how to clean up old symbols that you no longer need to track: Chart Data and Chart Data Files: Cleaning Up Old and Unused Symbols for Efficiency Then refer to the following section, to delete Intraday data files that you no longer need: Chart Data and Chart Data Files: Deleting a Chart Data File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
