Date/Time: Sun, 04 Oct 2026 02:28:37 +0000
Overlapping Labels
View Count: 1437
[2019-08-24 23:52:43]
jseppa - Posts: 18
Is there a way to prevent labels from overlapping?
Say when two lines are at the same or similar price, once label (right edge) completely covers the other. Is there any way to displace them automatically so both labels can always be seen?
[2019-08-26 10:18:06]
The most you can do is change the Vertical Alignment of the labels. Refer to:
Chart Studies: Subgraphs Tab >> Name and Value Labels
[2019-12-19 22:39:16]
User48838 - Posts: 131
You can also have one label with embedded spaces, like ' LOD' '5 min low'. LOD should be far enough to the right it wont cover the 5 min low label
