Date/Time: Mon, 20 May 2024 23:01:20 +0000
New Shortcut Please
View Count: 677
[2019-08-24 18:17:24] |
User923334 - Posts: 2 |
Hi, Can you make it possible to turn the << and >> underneath "UNIT" on the RPL (Replay Chart (Terminal)) a shortcut? Under Customize Keyboard Shortcuts under "Replay Chart" there is only the option for [Replay Chart (Control Panel), Play/Pause & Stop] yet nothing on << and >> Thank you. |
[2019-08-24 23:24:06] |
You are running an older version of Sierra Chart. Update to the current version: Software Download: Fast Update What you want is already supported. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-09-13 17:06:34] |
Hi can you make it possible that when we click Jump Forward or Backwards that the RPL terminal doesn't show up each time? The purpose of being able to put the Jump Forward & Backwards on the control bar or keyboard shortcut is so that I don't have to see the massive RPL terminal. Thank you. Love that you guys are always updating Sierra Chart, you guys are the best software out there! |
[2019-09-15 04:16:54] |
This will be resolved in the next release.
