Date/Time: Thu, 14 May 2026 11:07:01 +0000
real volume
View Count: 1784
| [2013-12-08 14:54:30] |
| User10739 - Posts: 18 |
does sierra chart provide the real volume And if so, whats the way to be appear on my chart thanks Date Time Of Last Edit: 2013-12-08 14:56:14
| [2013-12-08 19:32:39] |
What exactly do you mean by "real volume"?
| [2013-12-09 05:43:19] |
The number of traders..volume Of contracts of the buyers and sellers .. I'm talking about volume in general is that concept available ? Thanks
| [2013-12-09 16:50:41] |
We see you are using the Sierra Chart Forex Data service. For information about Forex volume, refer to: http://www.sierrachart.com/index.php?l=doc/SCRealTimeFOREX.php#VolumeData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-09 16:51:33
