Date/Time: Mon, 06 May 2024 20:24:48 +0000
#NUM! Value in cell $J$31 - PreRelease 1057
View Count: 1177
[2013-12-08 05:47:11] |
ezfcharts00049 - Posts: 15 |
Hello, PreRelease 1057 still has $NUM! value in cell $J$31 .... H. Oren |
[2013-12-09 17:57:42] |
Update to the current version by selecting Help >> Download Current Version. When you see this problem provide an image of the spreadsheet and attach it: https://www.sierrachart.com/index.php?l=PostingInformation.php#AttachFile Also let us know if you are running the non-CLR version of Sierra Chart? If you know. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-12-11 06:21:47] |
yes, I do. I am using : ABS, DAY, Hour, Minute functions |
