Date/Time: Mon, 29 Apr 2024 20:18:31 +0000
Failing to connect to DTN IQ feed
View Count: 1035
[2019-08-15 08:04:41] |
NigelDams - Posts: 9 |
I'm getting Windows error 10053 when trying to connect to IQFeed … here's an extract from the log: IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.08,0.07,, | 2019-08-15 08:50:08.922 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.15,0.07,, | 2019-08-15 08:50:09.921 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.22,0.07,, | 2019-08-15 08:50:10.924 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.29,0.07,, | 2019-08-15 08:50:11.925 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.36,0.07,, | 2019-08-15 08:50:12.921 Service connection timed out. Will disconnect and retry. | 2019-08-15 08:50:13.749 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2019-08-15 08:50:13.749 Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-15 08:50:13.749 IQFeed | Disconnected from Admin port. | 2019-08-15 08:50:13.760 Socket (1) | Shutdown started. Waiting for graceful close. | 2019-08-15 08:50:13.760 IQFeed | Disconnected. | 2019-08-15 08:50:13.760 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2019-08-15 08:50:13.760 Socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2019-08-15 08:50:13.761 * Socket (1) | Socket gracefully closed by remote side. | 2019-08-15 08:50:13.761 Socket (1) | Closed. | 2019-08-15 08:50:13.761 IQFeed | Connecting. | 2019-08-15 08:50:16.769 IQFeed | Starting interface software. | 2019-08-15 08:50:16.769 IQFeed | Connecting to Admin port 9300 | 2019-08-15 08:50:16.783 Socket (1) | Creating socket. | 2019-08-15 08:50:16.783 Socket (1) | Connecting to IP: 127.0.0.1. | 2019-08-15 08:50:16.783 IQFeed | Connected to Admin port. | 2019-08-15 08:50:16.785 IQFeed | AdminMessage: S,REGISTER CLIENT APP COMPLETED, | 2019-08-15 08:50:16.847 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.49,0.0,, | 2019-08-15 08:50:16.929 IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.56,0.10,, | 2019-08-15 08:50:17.920 |
[2019-08-15 08:34:15] |
This message indicates that the IQ Feed client software is not connecting to IQ Feed servers: IQFeed | AdminMessage: S,STATS,,,0,0,1,0,0,0,,,Not Connected,6.0.1.1,483588,0,0,,12.08,0.07,, | 2019-08-15 08:50:08.922
Follow the instructions at step 11 here: DTN IQ Feed Data Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-15 08:34:31
