Date/Time: Fri, 03 May 2024 04:02:02 +0000
Setup stocks data feed
View Count: 939
[2019-08-14 10:47:04] |
User841545 - Posts: 4 |
Hello, I would like to buy the advanced package but have a few questions, I will be using Interactive brokers as my broker and trading from your DOM. I would like to change my data feed, do you offer L2 data for stocks that will appear in the DOM? If you do, does it appear clean like it does for futures and can you tell me what I need to subscribe to exactly to get L2 data for all US stocks.. Thanks |
[2019-08-15 12:00:30] |
The Sierra Chart data feeds do not include the L2 stock data. Therefore you would need to use the data feed from Interactive Brokers: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-15 12:10:12] |
Does Denali feed have l2 for stock? The interactive brokers data feed isn't great and I want to avoid using it.
[2019-08-15 12:19:02] |
I also just connected to IB data feed, and L2 doesnt show, just bid and ask
[2019-08-15 20:26:02] |
No the Denali Exchange Data Feed does not have level 2 stock data. In regards to post #4, did you follow the instructions here: Interactive Brokers Trading Service: Accessing Level 2 / Market Depth Data for Stocks There are specific instructions to access the market depth data for stocks when using Interactive Brokers. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
