Date/Time: Sat, 27 Apr 2024 19:22:42 +0000
[Programming Help] - Daily Volume Tendencies
View Count: 892
[2019-08-14 10:23:04] |
YouPi - Posts: 2 |
Hello, I would like to study the average volume during a day by time (with a 5min time slot for example), to see when there is volume activity and when it is more calm. I mean take a sample of number of days, like one year, and make an average of the volume by time of the day of this whole year, to see any tendencies of the volume at certain hours. I hope this is clear enough. Would it be possible to do this? Sincerely, YouPi |
Example.png / V - Attached On 2019-08-14 10:17:47 UTC - Size: 19.08 KB - 271 views Attachment Deleted. |
[2019-08-14 17:11:16] |
Yes you can do this with the Relative Volume study: Relative Volume Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-25 08:05:16] |
User164231 - Posts: 278 |
Hi SC Engineer et al, Say I am using relative volume and I only want text value of the current bar to be shown on top of the bar under only 2 conditions; a. It is more than the average of last 20 days. b. It exceeds a certain value. What setting/study should I use? Please advise. Thanks |
