Date/Time: Sun, 05 May 2024 04:01:10 +0000
Bitcoin Bitstamp Volume wrong
View Count: 2906
[2013-12-07 20:47:01] |
robocoin - Posts: 4 |
http://i.imgur.com/oXraJuM.png ^i just found out that BSTMP volume reported in SC must be wrong. The screenshot shows SC volume (data was newly downloaded) in comprehension to bitcoinwisdom. I really like using volume related tools such as obv and vwma, but i can't with bstmp =( Date Time Of Last Edit: 2013-12-07 20:48:38
[2013-12-08 09:41:54] |
This problem is now solved. We will have to reload the historical data to get complete historical data. We have already done that for the last two days. It will take more time to reload the rest of the data. You can re-download the data in the chart to get more complete data to the extent that we have reloaded the data on our side. Go to the chart and select Edit >> Delete All Data and Download. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-08 09:42:23
[2013-12-08 14:44:20] |
OK. Looking forward.
[2013-12-09 23:58:42] |
Bitstamp historical data has been fully reloaded. Go to the BTC-BSTMP chart and select Edit >> Delete All Data and Download.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 00:03:52
[2013-12-10 01:59:21] |
Improved, but still different: http://i.imgur.com/LGC2uyx.png |
[2013-12-10 02:11:47] |
Different in what way? You should give a particular starting Date-Time and a timeframe per bar in comparison to another service. Or be more descriptive. You can also not reliably compare Daily bars because the starting times will be different almost certainly. You are also not using the correct volume study. You Need to use Volume-Bitcoin. Also Sierra Chart will drop any volume per trade which is after this amount of precision: .0000 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-12-10 02:13:39
[2013-12-10 03:34:26] |
I re-downloaded all data when you said it was fixed. But still got this: ([http://bitcoincharts.com/charts/bitstampUSD#rg60zigDailyzm1g10zm2g25zv] both UTC, bars starting at 00:00:00) http://i.imgur.com/d07aXp3.jpg I downloaded it again and it works: http://i.imgur.com/hHJ5LhE.png Thanks for your help and fast response! |
