Date/Time: Sat, 18 May 2024 20:43:31 +0000
Tool Values Window Custom Text
View Count: 729
[2019-08-12 16:27:02] |
brunor - Posts: 3 |
Is it possible to customize the text output in the Tool Values Window based on the value from the sc.Subgraph[]? For example, in the ACSIL custom study example function scsf_MarketStructure, the data in the subgraph is categorical and the tool values windows displays this data as a number (enum value) but it would be great if the window would be able to somehow display the actual text representation (HH, HL, etc..) of this data. |
sierra_tvw.png / V - Attached On 2019-08-12 16:23:07 UTC - Size: 29.38 KB - 263 views |
[2019-08-12 17:09:15] |
No, this is not supported.
[2019-08-12 19:38:17] |
User90125 - Posts: 715 |
Can the color be changed for the displayed output, without having to change it on the study subgraph itself?
