Date/Time: Sat, 18 May 2024 20:20:51 +0000
Trade dom bid/ask volume bar
View Count: 2042
[2019-08-12 16:22:43] |
User81245 - Posts: 5 |
How do I display the Trade dom bid/ask volume bar on the dom. I cannot find the setting
[2019-08-12 16:59:50] |
Volume bars for a particular column can be enabled through Trade >>Customize Chart/Trade DOM Columns. Refer to the documentation here: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 16:59:58
[2019-08-12 17:28:50] |
The option for bid volume bar and ask volume bar is simply not there
[2019-08-12 17:42:48] |
It should definitely be there in the version you are running. Here is a screenshot: https://www.sierrachart.com/images/CustomizeChartDOMColumns_ShowVolumeBars.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-12 17:43:12] |
And here is the relevant documentation again: Global Trade Settings Windows: Show Volume Bars (Trade >> Customize Chart/Trade DOM Columns) And be sure to refer to the above post as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
