Date/Time: Sun, 19 May 2024 01:12:07 +0000
Zig Zag study text labels
View Count: 596
[2019-08-12 13:15:58] |
Chris_uk - Posts: 89 |
Hi, Is there a way for the Zig Zag study to display text labels for 'Ask Bid Volume Difference' and 'Total Volume' for a swing concurrently? Please consider implementing this in a future release if it's not currently possible. Many Thanks! Date Time Of Last Edit: 2019-08-12 13:16:51
[2019-08-12 16:50:50] |
No, this is not supported. You just need to use another chart with another instance of the Zig Zag study configured as you require.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 16:51:25
