Date/Time: Tue, 21 May 2024 04:58:19 +0000
TPO profiles - Shortcut request
View Count: 822
[2019-08-12 09:28:35] |
User365411 - Posts: 178 |
If and when possible, can you add 2 switch or 2 default visualization that can be checked/unchecked in the right-click shortcut menu (img attached) for TPO profiles : - (In:19) "letter"/"block" visualization switch - (In:113) "no value data"/ "only value without label" visualization switch Another question, those commands in the shortcut list in the "Customize Keyboard Shortcut" window can be only added by you, right? Thank you |
TPO_shortcut.png / V - Attached On 2019-08-12 09:27:51 UTC - Size: 47.84 KB - 276 views |
[2019-08-12 16:06:10] |
Yes we can add these. Yes only we can add what is controllable through Customize Keyboard Shortcuts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-12 16:06:35
[2019-08-29 06:29:38] |
Acro - Posts: 436 |
+1 for post #1. The visualization switch (letters to blocks and vice versa) would be incredibly useful - both by mouse right click and keyboard shortuct |
[2019-09-16 12:15:25] |
Hi staff this is a 1 month bump, do you have an ETA for those requests? Ty |
[2019-12-09 22:14:04] |
- (In:19) "letter"/"block" visualization switch - (In:113) "no value data"/ "only value without label" visualization switch Hi staff, any news about my request? Thank you |
[2020-03-06 17:29:30] |
Release 2060 Thanks SC staff to add those 2 shortcut as requested. I found a little and annoying bug in the implementation of "Chart Values On/Off" command: after the right mouse click on "Chart Values ON/OFF" command all profiles originally set as "Show Chart Values On Profile Without Labels" switched to the unwanted " Show Chart Values On Profile With Labels In Single Row". Most of the time it happens after the first right-click, occasionally happens at the second right-click. Please can you check? TY Date Time Of Last Edit: 2020-03-06 17:29:58
Sierra Chart MainWindow 2020-03-06 18_26_48.388.png / V - Attached On 2020-03-06 17:28:10 UTC - Size: 121.96 KB - 257 views |
[2020-03-07 06:59:21] |
This is now resolved in version 2063.
