Date/Time: Sat, 18 May 2024 20:19:53 +0000
Countdown timer position bug
View Count: 619
[2019-08-12 13:33:47] |
User12167 - Posts: 16 |
I have experienced similar issues. The position only changes when the settings are saved as default and the study is removed and added back to the chart.
[2019-08-12 16:07:22] |
Yes this does make sense and is documented here with those Vertical/Horizontal Position inputs: Countdown Timer: Inputs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
