Date/Time: Sun, 19 May 2024 06:58:38 +0000
trial
View Count: 612
[2019-08-10 20:08:59] |
Pirate32 - Posts: 2 |
what is going on I paid and still cannot use? is this because of the convergent trading referral I can log in but cant use why let me log in if you are not activated stupid stupid stupid |
[2019-08-10 21:02:09] |
Your account has been unlocked and you can now use the system. This was only due to our checking to ensure that people are not able to manipulate the Trial system. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-10 23:38:40] |
You are always able to login and use certain functionality which is considered part of Free Mode. We believe it is a mistake to prevent the login. So at least you can still browse around the software and chart your existing data. So this is not "stupid stupid stupid" like you are saying. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-10 23:38:52
