Date/Time: Sat, 18 May 2024 20:43:24 +0000
Enhancement suggestion for the future.
View Count: 900
[2019-08-10 20:08:30] |
jsmanuse - Posts: 32 |
I know you all have bigger fish to fry - and this isn't really a problem it's just an idea that you might be able to use in the graphics department. On the chart I'm attaching you can see the arrow line goes through the text because of the way the text attaches at end of the arrow line. It would be even better if the arrow line project away from the end of the text window, if/when it is employed to identify information on the chart. I think Sierra charts is great.. and you are always innovating. Perhaps this will be another innovation down the road. http://www.sierrachart.com/image.php?Image=1565467364109.png |
[2019-08-10 23:30:38] |
We will need to add some text alignment options for the Arrow tool to solve this.
