Date/Time: Sun, 19 May 2024 05:06:24 +0000
charts reloading when switching back to previous timeframe (intraday)
View Count: 592
[2019-08-10 18:23:45] |
User138050 - Posts: 3 |
I am regularly switching between 1hour 2hour and 4hour timeframes on the same chart and am wondering whether it is possible to prevent the entire chart reloading and instead show the previous data that was downloaded the last time that timeframe was displayed (with only additional candles at the end added if there is new data) I have noticed this is default behaviour on timeframes greater than 1 day but not intraday. Is there a way to change intrday so it behaves the same way? Thanks I'd also be grateful if I could have some more time test out the software thanks |
[2019-08-10 23:24:19] |
There is a solution to this. To improve performance with the loading of Intraday chart data, refer to this section here: Changing Chart Bars Period: Improving Performance of Loading Chart Data We have added a week of usage time to your account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-10 23:24:31
