Date/Time: Mon, 29 Apr 2024 13:37:24 +0000
VWAP
View Count: 1664
[2019-08-10 16:19:48] |
John Ara - Posts: 125 |
I need to know how many ticks I am away from VWAP shown on a gragh or any way that can be known just by a glance. Please help me how I can do it. Thank you. |
[2019-08-10 16:32:35] |
In the end, you would need to use the Spreadsheet Study or the Spreadsheet Formula to do this, as you want to get number of ticks, which would require using a division by the special term TICKSIZE. If you do this on the Spreadsheet Study, you would enter the following in cell K3: = (E3 - ID1.SG1) / $J$21 Where ID1.SG1 needs to be changed to the particular subgraph of the VWAP subgraph. $J$21 is the Tick Size of the chart which is held in that particular cell. If you want to have the most recent value displayed in the chart, then use the Text Display for Study study. Refer to the following for the Spreadsheet Study: Using the Spreadsheet Study Refer to the following for the Text Dsiplay for Study: Text Display For Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-11 08:24:42] |
Ackin - Posts: 1865 |
Hi, you can download study for free from our CZ/SK forum (just Study in dll file, not code). Study name: How many ticks contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:35:37
[2019-08-11 16:29:12] |
The only file I found as attached to this thread is an image (png file). Please help me know how to access your mentioned study file. Thank you |
[2019-08-11 20:33:36] |
Date Time Of Last Edit: 2019-09-06 17:06:33
