Date/Time: Sat, 27 Apr 2024 21:06:15 +0000
Stop orders attached
View Count: 1235
[2019-08-09 18:14:05] |
User716575 - Posts: 24 |
Hi, I'm currently using an attached stop order. Is it possible to only have a stop attached to an entry only? Currently when I place an order to limit out it attaches a stop too. I would like to only have stops attached to entry's. Please let me know if I can do this. Thanks |
[2019-08-09 21:48:35] |
You can just have one attached Stop order and remove the Target order.
[2019-08-13 14:38:28] |
Thanks can you direct me on getting rid of the target order stops
[2019-08-13 23:56:59] |
You just simply select it from the list of Attached Orders and press the Remove button on the Targets tab of the Trade Window: Attached Orders: Step-By-Step Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-13 23:57:07
