Date/Time: Tue, 30 Apr 2024 10:58:09 +0000
Tick data export issue
View Count: 602
[2019-08-08 22:24:50] |
User740266 - Posts: 26 |
Is it possible to export tick data for each day into different seperate txt file format? For example, if I want to export 10 days of tick data, then there will be total of 10 txt files created in the data folder. Thank you. |
[2019-08-09 05:08:20] |
Yes but you have to do this manually. Once for each day. Also your Sierra Chart account is expired.
