Date/Time: Fri, 03 May 2024 09:13:17 +0000
Hogging resources which would be better for precise chart
View Count: 541
[2019-08-08 18:46:46] |
User450179 - Posts: 105 |
HI, I am using the precise accurate spread charts exactly as you state and it work. thank you. here is my question from a resource hogging standpoint. which one of these scenarios would use less computer resources or be "better" for speed of calculations downloads taxing cpu consider 1 instance 10 second granularity on all 3 charts. preices spread requires 3 charts. I want to chart 3 spreads but they all have 1 common leg which is crude oil 1.should i open 3 crude oil charts and 1 ng chart 1 ho chart and 1 rbob chart so I would then have 9 charts open or this 2. I open 1 crude oil chart and add the difference line study 3 times referenceing my ng, ho, rbob charts to reduce total charts to 7? 3. can you think of an even better and or easier way to do this with even less resources hogged? 4. would it better to make a custom symbol for each of these spreads and chart that? thank you in advance lets say the final chart has a 1 minute granularity using the 10 second data.. Date Time Of Last Edit: 2019-08-08 18:48:56
[2019-08-09 18:01:40] |
2. I open 1 crude oil chart and add the difference line study 3 times referenceing my ng, ho, rbob charts to reduce Yes this is the way to do it.total charts to 7? 3, 4. Yes using a custom symbol would be the best way but there is not going to be historical data other than what is recorded when connected to the data feed , but historical data support will be worked on this year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
