Date/Time: Thu, 16 May 2024 15:28:42 +0000
Right-click menu item on drawing only shows 8 config items
View Count: 750
[2019-08-08 04:13:33] |
User735389 - Posts: 188 |
I notice when i right click a drawing, the menu item only shows 8 config items. If i select the drawing, then right click away from it, it will show the additional menu items that i configured it for. Is there a way to adjust this behavior?
[2019-08-08 10:06:18] |
You need to customize the Chart Drawing Menu as you require: Global Settings Menu: Customize Chart Drawing Menu (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
