Date/Time: Thu, 16 May 2024 09:48:30 +0000
Control Bar Floats outside screen range
View Count: 998
[2019-08-07 14:26:14] |
tomas262 - Posts: 135 |
Hello, I had control bar fixed at the top. When I click to "float" the control bar detached and moved outside the screen range so I cannot pull it back and fix it How can I revert it back? Thanks |
[2019-08-07 16:22:07] |
John - SC Support - Posts: 31666 |
Select Windows >> Reset Windows. This should bring the Control Bar back into view at the top left of the chart, and you can move it again from there. Refer to the following: Control Bar: Unable to Make Control Bar Visible For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-07 18:50:22
