Date/Time: Thu, 02 May 2024 01:43:07 +0000
Data directory
View Count: 1171
[2013-12-06 08:13:11] |
User42282 - Posts: 41 |
Hi, I wonder if it would be possible to have an option of SC ALWAYS using "data" directory within current sierrachart.exe path. It would simplify portability and (for me) it would prevent many problems, cross refernces and so on. For backup testing, I want to use various setups so I simply clone current directory of SC--which I think many people do. But sometimes I forget to change data directory in general settings; other pitty is that SC uses non-reletive path in File->recent file list. I did a mistake so many times! Thank you for considering this wish :-) Mirek |
[2013-12-09 16:56:06] |
We will add support for both of these.
[2014-01-08 10:59:34] |
Hi, thank you for implementing "Always Use 'Data' Folder within Main Folder". It is great! I still miss the second related thing -- relative paths in File -> Recent file list. Thank you once again. Mirek |
