Date/Time: Mon, 06 May 2024 00:18:43 +0000
OCO orders managed by Sierra Chart for TWS
View Count: 1535
[2013-12-05 20:53:58] |
TPeirce - Posts: 27 |
Currently do OCO orders managed by Sierra Chart appear in TWS after the parent order is filled? There is a seperate discussion where IB managed OCO orders are not entering a stop and a target in TWS. (Where the option to "Use IB managed OCO and bracket orders" is enabled). Version 1016 / TWS Build 939.3 |
[2013-12-05 23:08:27] |
Yes, this is correct. Support for Interactive Brokers bracket orders will be coming later on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-26 04:55:09] |
We have released support for server side bracket orders with IB: Upcoming Development | Post: 38686 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
