Date/Time: Sat, 18 May 2024 22:04:17 +0000
Correlation percent change chart
View Count: 1385
[2019-08-04 14:22:17] |
Chris_uk - Posts: 89 |
Hello, I have built the chart featured in the screen shot using multiple 'overlay(single line)' and 'Percent change since open' studies. Is this the best way to build a correlation/percent change chart for multiple instruments? Is it possible to hide the main chart window, I have put the studies in region one and the main price graph in region 2 but would prefer to only have the overlays and studies displayed. http://www.sierrachart.com/image.php?Image=1564927669978.png Would it be at all possible to have an option for the 'percent change' study to start from the beginning of month, week and year please? Many thanks! |
[2019-08-05 04:44:28] |
You really want to use this study instead of the Overlay study: Add Additional Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
