Date/Time: Sat, 18 May 2024 21:54:47 +0000
Bitmex and SC DOM (Entry price) differ
View Count: 599
[2019-08-04 09:12:16] |
User674760 - Posts: 1 |
Hi Support, I am getting many instances of BitMex and SC DOM having two differing Position Entry prices, this is very frustrating as SC shows one price and BITMEX another affecting performance, I have screen recorded this and add a couple of instances of this for you. Could you please investigate what is causing this? Regards, https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30419 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30420 https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=30421 |
[2019-08-04 21:34:27] |
There are different Position Average Price calculation methods available including being able to use the external service average. Refer to: Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-04 21:34:39
