Date/Time: Sat, 18 May 2024 18:46:28 +0000
Control Bar
View Count: 501
[2019-08-02 20:48:06] |
User807026 - Posts: 86 |
On my last update of Sierra Chart (1964, all the icons on the control bar changed to letter from icons. I think I have read everything about the Control Bar but I don't see anything on how to change letters back to icons. How do I do that?
[2019-08-03 09:10:32] |
We want you to use version 1967. Follow the instructions here: Software Download: Fast Update And if you still see text, follow the instructions here to select the image: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
