Date/Time: Sat, 18 May 2024 19:50:35 +0000
Auto Connection to Transact
View Count: 526
[2019-08-02 19:25:43] |
wingz - Posts: 121 |
For the last few days.........if I have the Transact data feed open, Sierra is auto connecting to Transact, even though I have the auto connect disabled in Sierra. I went into the Sierra Data/Trade Service Settings to confirm that the auto connect was off.....and it was. "Reconnect on Failure" was checked so I unchecked it. Please let me know if unchecking that is going to cause any problems. I have always connected manually to Transact after opening Sierra and I much prefer doing it that way. Thanks.
[2019-08-03 09:52:07] |
No, there is no problem with doing this.
