Date/Time: Sat, 18 May 2024 19:51:33 +0000
Live data on two computers
View Count: 650
[2019-08-02 15:21:49] |
User536105 - Posts: 36 |
If I have properly subscribed all fees for live data, can I open Sierra Chart on two computers to receive live data using the same account? Also, if I want to open on three computers at the same time, I just need to subsribe for one more system is alright? Do I need to additionally pay for more exchange / real time connection fee? Thanks.
[2019-08-02 17:05:08] |
Sierra Chart - Max - Posts: 5618 |
Yes, you would need to pay for an additional Real-Time connection too. You need a Real-Time connection for each Sierra Chart instance that you would like to be connected to the Exchange Data Feed. Sierra Chart Support Date Time Of Last Edit: 2019-08-02 17:05:39
[2019-08-02 18:09:19] |
Thanks, so I only need to pay one exchange data feed for one sierra account now matter how many systems I use right?
[2019-08-03 12:12:32] |
You do need to pay for an additional real-time connection for each running instance of Sierra Chart which is using your same Sierra Chart account. Refer to: Sierra Chart Exchange Data Feed: Data Feed Pricing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-03 12:12:52
