Date/Time: Sat, 04 May 2024 07:46:50 +0000
Sierra Chart Export Function Keeps Getting Cut Off
View Count: 682
[2019-08-02 00:59:11] |
Rain - Posts: 4 |
Hello! I am trying to export my trade activity and for some reason, it only exports half? The rest is getting cut off? This is everything that has data in Sierra but does not export. FlatToFlat Max Open Loss (P) Max Open Profit (P) Max Open Loss (P) Entry Efficiency Exit Efficiency Total Efficiency Commission (C) High Price While Open Low Price While Open Note Open Position Quantity Close Position Quantity |
[2019-08-02 01:08:25] |
How do you come to this conclusion?: it only exports half? The rest is getting cut off?
We had a look at the original file you gave us through a ticket and all the data is there because we can see a Total line at the bottom.
[2019-08-02 01:41:39] |
Rain - Posts: 4 |
Hi, just curious then, should these be filled in with something? I am trying to export it into edgewonk journal and they said the sample needs to look like what they have. And I been struggling to get this working. Any help would be tremendously appreciated. |
filler1.JPG / V - Attached On 2019-08-02 01:40:08 UTC - Size: 105.6 KB - 229 views Attachment Deleted. Sierra.sample.txt - Attached On 2019-08-02 01:41:34 UTC - Size: 334 B - 248 views |
[2019-08-02 04:57:15] |
Neither of those attachments are a help to us. We cannot understand the first one and the second one only has a header line. The data is definitely exported properly. This there can be no doubt about.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-02 04:57:45
[2019-08-02 06:37:13] |
Rain - Posts: 4 |
Its missing half of it though.
[2019-08-03 10:02:42] |
You are exporting the Trades tab and what you see in the file is going to match the Trades tab of the Trade Activity Log. If you see a difference, we need you to point that out by providing the actual exported file, and tell us the line number and then show a screenshot of that line from the Trades tab. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-09 05:20:11
[2019-08-06 01:27:04] |
Rain - Posts: 4 |
Okay here is the trade activity log straight from Sierra Charts. This is the information that somehow keeps getting cut off when I export it from Sierra. If you know a way to fix this it will be greatly appreciated. |
cut off1.JPG / V - Attached On 2019-08-06 01:26:24 UTC - Size: 360.97 KB - 259 views |
[2019-08-09 05:20:47] |
But this does not show us anything is getting cut off. We would also need to see the Date-Time column in the Trades tab. And the actual exported file. That needs to be attached. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-09 05:21:23
