Date/Time: Sat, 18 May 2024 23:29:51 +0000
Trade Activity Log
View Count: 932
[2013-12-05 17:12:33] |
pismo10 - Posts: 158 |
On the activity log is there a way to sort the trades so that they don't go off the screen after a certain number of trades. Say reverse time would do it. Now it is sorted by advancing time so the most current trades are on the bottom and will go off the screen after too many trade. Thanks |
[2013-12-05 17:31:58] |
Eventually we will add the ability to reverse the order of the displayed lines in the Trade Activity Log. For now select the very last line in the Trade Activity tab in the Trade Activity Log, and when a new line is added it will scroll automatically to it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-06 19:01:28] |
User889191 - Posts: 61 |
It is really a basic feature that one should be able to sort on any column. Please add it in next release.
[2016-10-06 22:10:03] |
We do not agree. That is a log which the entries are ordered by time. It would make no sense to sort by any column and it would be very detrimental to users and for us if that were the case. So you can be assured this would never come. Also that type of sorting is immensely complicated and has a huge performance impact if implemented. You already have the ability to filter the log by Date-Time, Symbol, Trade Account, and Activity Type. We may also add the ability to filter by Internal Order ID. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-06 22:16:14
[2016-10-06 23:17:29] |
If you could do just the trade time that would be helpful. I understand there are a lot of fields and all of them would be a problem..
[2016-10-06 23:18:28] |
This has been supported for a long time now. Edit >> Descending Display Order.
[2016-10-07 12:56:09] |
Unfortunately this is not available in the Trades tab where for me would be most valuable.
