Date/Time: Sun, 19 May 2024 11:05:44 +0000
Vertical Scaling Issue Question
View Count: 588
[2019-08-01 23:17:07] |
User429065 - Posts: 109 |
Attached is a chartbook with a 15-minute chart and a 4-tick Renko chart using the same collection of studies. A MACD has been placed independently on region 1 along with a few other studies. The vertical scaling on the 4-tick Renko chart is correct but is NOT correct on the 15-minute chart. This appears to be an issue with the last 2 versions of SC. Please advise. Thank you very much!
Date Time Of Last Edit: 2019-08-01 23:20:28
Chartbook for Support.Cht - Attached On 2019-08-01 23:03:37 UTC - Size: 172.52 KB - 247 views |
[2019-08-02 00:22:35] |
There definitely is no problem in the new version in regards to this. That is for certain. This is what we are seeing: http://www.sierrachart.com/image.php?Image=1564705326674.png what is the problem with what you are seeing? It looks ok for us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
