Date/Time: Sun, 19 May 2024 11:41:18 +0000
System Notification Message
View Count: 619
[2019-08-01 23:09:50] |
User568537 - Posts: 21 |
When I start SC the first window to open is a "System Notification Message" and it says "Press 'View in Web Browser' to see complete message"; however the browser shows only a blank page and points to C:/SierraChart/SierraChartTransActMA/Data/SystemNotificationMessage.html. What kind of message is SC trying to notify? |
[2019-08-01 23:26:55] |
There is no message. Disregard. We hope you did not call Transact about this. Do not bother them about this.
[2019-08-01 23:54:02] |
Ok, thanks (I bothered only you)
[2019-08-02 00:01:15] |
That is good. We hope nobody called Transact about that. There should have been no message displayed. But inadvertently there was a blank one displayed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-02 00:03:32
