Date/Time: Sat, 18 May 2024 23:42:01 +0000
Install current version
View Count: 661
[2019-08-01 23:05:59] |
John Mc - Posts: 32 |
I keep getting a message that there is a new version. When I go through the process to install it it tells me it has been downloaded tells you that Sierra needs to close. I click yes and the screen goes blank and nothing happens. How do I install the current version?
[2019-08-01 23:56:39] |
This is just a Windows 10 problem. Install the current version of Sierra Chart from this page: Software Download: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-02 14:45:02] |
I tried this but still get the same results. I turned off my virus protection before trying the update.
[2019-08-02 18:29:47] |
Something on your computer is blocking running the installer then.
[2019-08-05 01:01:32] |
OK, I will do some troubleshooting. Can you tell me what folder the new version gets downloaded to? I want to make sure Sierra can write (download) to this folder. |
[2019-08-05 02:49:01] |
Can you tell me what folder the new version gets downloaded to? If you are downloading the Sierra Chart installer from this website, where it is downloaded to is controlled by your web browser.If you are updating within Sierra Chart using Help >> Download Current Version then the installer is written by default to C:\SierraChart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-05 02:49:12
