Date/Time: Sun, 19 May 2024 05:07:25 +0000
Real Time Tick Size Subgraph Value Study
View Count: 919
[2019-07-31 17:07:29] |
mommed.imam - Posts: 13 |
Hello, I am kindly asking, if it possible to have a real time tick size sub-graph value, which is reading, in real time, the increase in tick size, for example, the ES future indices have a min price move of 0.25 ( min tick size), I would like to have a study that gives in real time the change (increase) in tick size, suppose that the ES future has moved with 0.5 step instead of the min tick size of 0.25, the study should report this tick size increase as study sub-graph value in real time, basically this study, compare the last tick price to the current tick price to determine the tick size, and continues doing so in a closed loop, tick by tick! for example, suppose that the last ES future tick price is 3000.25, and the current tick price is 3000.75, then the current tick size is 0.50 tick not 0.25 tick ( 3000.75-3000.25), could you please help, and advice on how to get this done? Thank you! |
[2019-08-01 08:50:53] |
There is no study that Sierra Chart has to do this but you could certainly create a study that does this. For information about accessing individual trades, refer to this section here: ACSIL Programming Concepts: Combining Intraday Chart File Records into Original Summary Trade Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-01 14:49:10] |
Thank you very much indeed for your help. The Study idea, is basically a closed loop logic, which continuously "in real time- no lag" calculates tick size by using this formula ( Tick Size = the current bid tick price - the previous bid tick price), the study should report this tick size value " in real time- no lag", and continue doing so in a closed automatic loop, tick by tick! I am willing to pay to get this trading idea coded into custom study with subraph value, so could you please help and advice? Thank you! |
[2019-08-01 21:24:56] |
This is not within the scope of our support. We do not provide programming help. See if you can find a programmer here: List of Third Party Sierra Chart Study and System Programmers Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-01 21:25:36
