Date/Time: Sat, 27 Apr 2024 18:11:01 +0000
Point on close on TIME LINE
View Count: 1085
[2019-07-31 13:26:12] |
User75949 - Posts: 108 |
to give the possibility to draw a POINT ON CLOSE instead of a vertical line, you should add the possibility to set on TimeLine(SG1) POINT ON CLOSE instead of Point on High or Point on close that is actually not precise when you want to Highlight with a point the CLOSE of the Regular Trading Hours. Thank you |
[2019-08-01 09:09:59] |
You can modify that study to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-01 10:17:30] |
Ackin - Posts: 1865 |
User75949) Hi, you can download modified study for free from our CZ/SK forum (just Study in dll file, not code). Study: Time line - improved contact link: https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free Date Time Of Last Edit: 2020-06-24 22:31:22
[2019-08-01 10:51:01] |
Thank you Ackhin, I tried to register to your forum with no success..
[2019-08-01 10:58:36] |
Send me via Direct Message your email and nick, I'll create access for you...
[2019-08-01 13:04:49] |
Ok Ackin, done. tks bye |
