Date/Time: Sun, 19 May 2024 05:24:30 +0000
HELP CALIBRATING KELTNER CHANNEL
View Count: 1161
[2019-07-30 18:37:32] |
User642945 - Posts: 9 |
Hello, I am looking to make a Keltner Channel with a 100 period look back with 10 standard deviations What would I input for the settings here on Sierra to make this happen? I included a picture Thank you! |
Screen Shot 2019-07-30 at 2.35.23 PM.png / V - Attached On 2019-07-30 18:37:15 UTC - Size: 35.56 KB - 367 views Attachment Deleted. |
[2019-07-30 19:25:49] |
User90125 - Posts: 715 |
Keltner Channels do not use Standard Deviations at all. So there is nothing to "calibrate" in that regard.
[2019-08-02 06:08:30] |
Here is the documentation for the study: Keltner Channel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
