Date/Time: Mon, 13 May 2024 03:28:20 +0000
DOMs/Price ladder
View Count: 1548
[2019-07-30 16:19:43] |
User191165 - Posts: 28 |
Hello, I am running 2 doms side by side emini S&P500 & emicro S&P5oo. I am using emini Dom to read orderflow & use volume profile & using emicro Dom to place trades. My question is.... Is there a way in which I can place orders on the Emini Dom (so I can fully focus on the OF) which would be in SIM, and have the orders replicated automatically on the emicro Dom which would be LIVE? Regards Baz |
[2019-07-30 17:45:16] |
Yes you can do this. Just enter the micro symbol in the Chart Settings for the chart or Trading DOM that you want to trade it from, in the Trade and Current Quote Symbol box. Refer to: Chart Settings: Trade and Current Quote Symbol (text box) (Chart >> Chart Settings >> Symbol >> Symbol menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-30 17:48:19
