Date/Time: Sun, 12 May 2024 04:48:58 +0000
Not Connected / why
View Count: 1160
[2019-07-30 14:50:59] |
User38606 - Posts: 80 |
Hi, I can see my station as being Not Connected! what is wrong? I am using version 1310 and have paid the membership fees.
[2019-07-30 17:15:07] |
In regards to using versions prior to 1600 with Sierra Chart data feeds, due to a server update those are no longer able to connect to the data servers for real-time data. You need to update to the current version. You can install that from this page: Software Download Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-07-30 17:15:32
