Date/Time: Sun, 19 May 2024 08:35:26 +0000
Control Bar ver. 1961
View Count: 691
[2019-07-30 09:58:01] |
nicktrader - Posts: 665 |
The new version (1961) changed some commands of the Control Bar into text (see pic)
Control Bar 1961 vs 1957.png / V - Attached On 2019-07-30 09:57:17 UTC - Size: 31.13 KB - 346 views |
[2019-07-30 11:07:12] |
You need to go into the Control Bar properties for those buttons and choose to use the image. You do not have to specify any image file. The default will be used. Refer to: Control Bar: Control Bar Button Properties Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-07-30 13:44:07] |
The buttons properties changed after downloading current version (1961) and a new start. If I go back to ver. 1957 everything is fine. From my point of view a bug. Why should I do this as you suggested? It is much easier - for all of us - to fix that (little) bug. Many txs |
[2019-07-30 17:52:02] |
We are still doing work related to this. There may or may not be a problem here. If you you have set different Properties for a Control Bar button, those will be applied to the button rather than the defaults. The problem previously was that if you set a text caption for a button that by default used an icon image, and that caption was the same as the default, it would not be used. This is resolved but we are still working on this. So wait for the next release. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-08-02 05:35:34] |
I was still running the current version 1967 (now back to 1959) but you can't change some buttoms (e.g. "Zoom In" or "Tool Value Window"). There is no way to get a image (instead of Text or you have set a button). Version 1959 do not have that problem (see pic). It do not care if you set capture or image. In both cases you get an image. If you reset you get an image.. |
buttons ver1959.png / V - Attached On 2019-08-02 05:34:12 UTC - Size: 13.06 KB - 194 views |
[2019-08-02 06:33:29] |
In version 1967 you can set either an image or text and choose using the drop down.
[2019-08-02 09:24:39] |
I tried this before and no change. I tried different ways with the Zoom In Button(see pic numbers). 1. Status after download rev. 1967 2. I set Image and Reset 3. No change after reset (only color) and I choosed Caption ==>> also no change Other buttons are working after setting but other (like ZoomIn) do not work. |
Button Example Zoom In.png / V - Attached On 2019-08-02 09:24:32 UTC - Size: 45.12 KB - 309 views |
